Centering Steering Wheel
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
Morning gang, wondering if there is a trick to centering the steering wheel that does not involve removing it? With my drives straight, my wheel is turned past 90 degrees to starboard. Not the end of the world but sure would be nice for it to be relatively straight. I have tried 4 sets of allen wrenches, metric and std, to try to back out the screws in the mid hub to remove and re center and nothing fits. If I ever have to remove I may need to drill out. Anyway if there is another way I am all ears. I plan to add the davis position indicator also.
to the rack.
caps can be purchased if you have to break it to back screws out. Then get new screws
or google search
Greg your right! Thanks! Now just use a socket to remove this nut? Simple as that?
like I said earlier in the post all center plugs comwe out.
some have one or two set screws that hold them in place from the side.
