I have a 2006 340, twin 270 Volvo engines with the new metal outdrives. What RPMs for best efficency
For the best plane I have to run between3500 and 4000. Seems like I an spinning the engines way to high. the trim is set down
Usually - but NOT always - the rpm to mph ratio dictates the best fuel economy. So, I'd get the boat on plane back off until it started to porpoise or feel like it wanted to slip off plane then slightly increase the rpms. Once you find the sweet spot on plane you can tap the throttles back until your mph start to drop. At that point you are probably at your best fuel efficiency. I have tested this against the data from my vessel view readings and found it to be very accurate. As Al said wind, temperature, humidity, wave action, hull cleanliness and hull design all change settings, but what I mentioned doing worked very well for me. After a while with your boat you will be able to feel and hear when you are at or close to your best rpms.
