plumbing fittings/ FLAIR IT fittings
Hey all, a while ago my water heater tube/pipes suffered a squish. Why I was thinking I could stand on them is beyond me. Anyway, the tubes pulled out of the fittings going into the water heater. THe water heater fittings are intact, but the hoses are disconnected. I have the replacement tube/hose. I have the old fittings (think plastic compression fitting). My question is, Since the hose/tube is almost the same size as the fittings, do I just gently heat the tube with a heat gun and shove it on the fitting?
I have googled Flair it fittings and all the vids show that this is the way to do it. I also googled how to change the rear struts on a honda, the vids didnt show that you will also have bolts break and bolts corroded in bushings so you have to change them as well. So Im thinking ask people who have really done it regarding the fittings
Thanks
Steve
Thanks
Steve
Thanks
Steve
Also, after I connected the heater, when the pump was running The engine made a bubbling noise
