and why did i do that
Finally, the water system is running again on the 265 (1995)
after rebuilding the main water pump and then replacing the main water pump, btw dont bother rebuilding them, Yes shurflo sells the replacement rubbers, but they dont sell the replacement motors alone. You will rebuild the pump only to find a week later the motor is full of corrosion and then you will have to replace the whole assembly. Not worth it, just replace the whole dang thing.
Then replacing the shower pump, make sure you put the filter on the shower side, other wise you will pull the pump out to clean the rubber parts of sand, (three times, Im a little slow somedays)
Thennnnnnn fixing the hot water hoses, NEVER STAND ON THEM, they will pop off the water heater. Dont reuse them if you do, they kink and the kink is now a weak spot in the tubing. When you have a weak spot, it leaks all over the electic connection for the water heater. It makes a funny sound when the water was boiling off because of the corrosion in the connections caused by the leak (all clean and shiny now).
oh, if you are ever reviving a water heater, after all the connections are made and you turn on the water pump. If the bilge is filling up with water and you have no water pressure at the faucet, you forgot to shut the water heater drain.
Why did I do all this now at the end of the season, I have no clue. but its done and I now have HOT water and serious water pressure. In fact I think the 3gpm pump is a little too much. Oh well,.
Thanks for the rambling
One last tidbit, If you decide to take the boat out with less than a 1/4 tank of gas, make sure you go upstream to the next marina that sells gas, that way when you get to the marina and the gas pumps are turned off, you can drift back to your dock.
BD, couldn't have said it better. To add to his comments, if you are doing it yourself, you are already saving money. I have a leaky seawater pump right now. I'm waiting till spring at this point (cause it's time to replace impeller on old one too, so new for both in spring instead of buying and leaving new impeller set all winter) and replace the entire thing. On my last boat I had tried to take one apart that leaked and luckily before I went too far, I had a mechanic tell me he had never seen anyone get it back together without issues.
I guess I'm going on and on, but my point is you'll still make out better replacing the entire part than paying someone else.
Im still having problems wrapping my head around the fact that parts are getting cheaper and easier. I used to rebuild alternators for the price of a new one today
