270 modifications - lets see the ones you are proud of!
Anything at all, lets see the coolest thing you've done to your 270... anything from new chart plotters, to led lighting, to simple mods.
Need some ideas for winter!
@randy56! Done right!.....love the drive shower!
Question: how does that stabilizer fin work? I tried one (Stingray brand) on my 190 Rinker 350 mag and it made the boat squirrely. I assume it works for you to jump on plane then at that point it is out of the water..... and also stabilizes the boat at low speed cruising, like around 1100RPM?
@Handymans342, The PO kept in it in a huge marina, in the water, no lift. inherited problem.
@randy56, I can't open your post but from the description of your link I think you found them!
Mine had thin round caps with a post with fins attached. You just snapped them into the holes. The posts came in different diameters. They lasted for years then I sold the drive and replaced it with a Bravo 1. Last I heard they were still good.
The best feature was that being plastic they never corroded and the fins held them in place. They looked oem. You would never have guessed they didn't come from the factory like that.
I'll see if I can find one tonight. If it's still in its bag I'll post a part number
I used the toilet cleaner before on the bow area to remove spider and bird droppings, it works pretty good.
