Engine hatch opening with emergency posts on EC 360
Has anyone had any experience with opening and closing the engine compartment hatch once batteries have been disconnected? We tried using the emergency hatch contacts in the switch panel. Put 12 volts across connectors and the hatch opens, but when we reversed polarity the hatch motor did not close. I would think it would work that way, but it didn't. Do any of you have insight to how those posts work?
Best Answers
DanD2 Member Posts: 848 ✭✭✭
Reversing polarity should work. You sure nothing is holding it up. Did you double check your connection? If you don't hear the motor running, then the connection might be bad
No longer a boat owner.....previous boat - 2005 Rinker Fiesta Vee 342 -
Michael T Member Posts: 7,227 ✭✭✭✭✭
I had a 2014 EC 360. I had to try several times once. I think ram actuator must take a fair bit of amps so you have to have a really good connection on the posts...... P.S. and a good battery - had to go get another shop battery once as the first one didn't have enough juice! -
Dream_Inn Member, Moderator Posts: 7,714 mod
I know some years/models only using the emergency post will allow you to lift the hatch, not lower it. Not sure the exact years/models that was the case though.Dream 'Inn III -- 2008 400 Express
Good luck! That hatch is horrendously heavy!!
Yep, you should try it on a 400! I pulled my shoulder with mine. I did figure out a better way using leverage and some lines. 4 people (2 in front and 2 on swim platform pulling back) and an additional person to tie off the line holding it up.
I'm just glad there is actually a way to do it...
Not all models have that capability.
