Anyone have a bilge pump installed that completely dries the bilge with a flip of a switch?
I seem to have some kind of problem with water in the bilge. It's a 270 2004 FV.. I've read a ton of threads about it... seems like a common problem with rainwater from the blower vent (I mean cmon, we haven't fixed this yet in 2016?) could be a fresh water leak problem, could be 10 other things.. The main problem is this water gathers in my bilge and it STINKS!! Like nasty eggs! It's so bad that when the engine room heats up the smell goes up in the area that is under the garbage can and then comes out of where the door slides open/closed...and you can smell it when underway!! (but thankfully it doesn't go downstairs) I go down with a wet dry vac, pull it out and it's fine again for the weekend...
I will investigate this over the winter and search for where the water is coming from (haven't used the AC in a month), but at the same time I would like to find out if there's also a solution to get the bilge completely dry (or at least no puddles) with the flick of a switch. Don't care how much work it's going to take, does anyone have a solution they came up with that works great?
Post edited by J3ff on
The only possibility I can think of is a shop-vac with a hose to the lowest part of the bilge. But the shop-vac would have to be mounted outside the engine room. It quickly turns into a Rube Goldberg machine.
anyone?
Enough of vacuming water in the bige in the search box of the forum
I wanted to do this while the motor was being replaced, but the owner of the shop wouldn't let me in the boat while things were underway. I then paid them a couple hundred bucks to "clean the bilge" which I was hoping would mean exactly what you said, scrubbing with soap/hotwater/chemicals and completely getting the bilge spotless. They charged me but whatever they did didn't alleviate this problem. I don't really have any way to prove one way or another if they did a good job or not. At the time it was most important to get the thing running again.
the SS screen you can buy from Home Depot.com but I bought mine at Dollar King in Canada (1.00$)and cut the bottom out to make it fit the hose.
Here is the link
https://www.amazon.ca/gp/product/B00OLKTD0S/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1.
hope this help
I used my raw water wash out pump that was factory installed and intended to use the raw water (bay water) to wash out the cockpit (not going to happen). So, I removed the hose from the seacock and put a new one on that went to the drain plug area. Now, with a flip of the switch, I completely drain the bilge. Works really well and fortunately everything was already there.
I am very particular about the bilge and clean it often with purple power. But yet, if you leave the water in there, it will really stink as you mentioned. Has nothing to do with leaks, it's just rain water getting in and then heating up as you mentioned and getting nasty. The simple pump you are looking at should work fine. Please take pics of the install so others may learn.
Yesterday I left the bilge completely dry, 5 gallons out... can't go down to the boat today, it's going to rain tomorrow, will check it out on Friday.
I think for now I'm going to leave it as is and just use the shop vac since the boat comes out of the water on the 27th, but over the winter I will def be trying to replicate what we've got here. Will take pictures and document it.
Here's the thing... every boat I've owned has always had water in the bilge, all season... why does the rinker water in the bilge stink so much?!? None of the other boats (3 or 4) have ever smelled like this.
