Front AC condensate drain
@Alswagg ... Quick question for you. I kept getting water running into my bilge where my rear AC unit is. After following the flow, I found the source. There is a bilge under the front AC condensate pan. I was completely filled with stale smelly water. I wet-vac'ed the water out (18 gallons) and poked around a little in there. Seems the water was coming from the condensate of the front AC unit. It was dripping into the pan, overflowing the pan, running into that bilge, and then when the boat moved, it was working its way all the way to the rear berth AC bilge, where it was picked up by the pump and discharged.
The hose from the bottom of the condensate pan, led to a scupper down by the waterline, port side near the bow. However, this hose appeared to be too long and arched "above" the top of the condensate pan. The water could not run "uphill" through the hose, so it spilled over the pan into that front bilge. I want to cut that hose and re-route it downward to the scupper so the water flows out. Is there a reason why this hose was like this from the factory, or is it an oversight at the time of production. And is there anything (other than making sure the scupper is facing aft) I should know before I cut that hose.
Thanks
Mike
Thanks
Mike
Best Answer
Dirtythirty Member Posts: 393 ✭✭✭
Something that might not have been present at the end of the assembly line
Heard back from Al, he stated he is pretty sure the drain line being too long and arching upwards was an oversight in production. Just really irritates me that something so simple can go un-noticed by their QC guys. AND...It's been like that for 8 years and now its being addressed for the 1st time.
