Seawater Pump
onislandtime
Member Posts: 309 ✭✭✭
Hey guys, I have noticed rust water underneath the pulley of the
seawater pump. I understand the bearings are shot. Do I replace just the
pulley or does the seawater pump have to be replaced also?
Mercrusier 350 MPI bravo III
just like it would be for the engine pump
housing n impeller
Last water pump you'll ever need. Any questions, call them. Their customer service is pretty good.
Yes just the front,need tool to pull pulley,and press back on.
I checked out the Hardin Marine and like what I see! Thanks
http://www.homedepot.com/p/GearWrench-Indexing-Combination-Ratcheting-Wrench-Set-12-Piece-85488/204621316
It will cut the job time in half compared to a straight combo wrench.
remove bolts form bracket pull pump a little forward then losing hoses.they are right under the motor mount
