Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Seawater Pump
onislandtimeonislandtime Goose Bay Marina, MarylandPosts: 248Member ✭✭
Hey guys, I have noticed rust water underneath the pulley of the seawater pump. I understand the bearings are shot. Do I replace just the pulley or does the seawater pump have to be replaced also?
Mercrusier 350 MPI bravo III
  • zaverin1zaverin1 Saint Clair Shores,MIPosts: 1,378Member ✭✭✭
    The entire housing
    just like it would be for the engine pump
  • onislandtimeonislandtime Goose Bay Marina, MarylandPosts: 248Member ✭✭
    I seem not to be able to find the pulley attached to the pump. I have air fittings but Im thinking I only have to replace the front part. Am I correct or not?
    Pulley is fine
    housing n impeller
  • Black_DiamondBlack_Diamond Holland, MichiganPosts: 4,366Member ✭✭✭✭✭
    Go with the Hardin Marine SS replacement pump.
    2003 342FV "Black Diamond", 350 MAG MPI, 20P 4x4 Props, PC BYC, Holland, MI
  • LaReaLaRea Alexandria VirginiaPosts: 2,949Member ✭✭✭✭✭
    +1 Hardin Marine
    Last water pump you'll ever need.  Any questions, call them.  Their customer service is pretty good.
  • reneechris14reneechris14 Pawcatuck river CTPosts: 1,661Member ✭✭✭✭
    +2 harding Marine
    Yes just the front,need tool to pull pulley,and press back on.
    @LaRea I'm mechanically incline. Is this a project easily performed?
    I checked out the Hardin Marine and like what I see! Thanks
    Oh yeah. Hardest part is just getting the old one out with the usual contortions required. lol.
  • rasburyrasbury Sanford, FLPosts: 4,496Member ✭✭✭✭
    If you can stand on your head you can do it!
    If you like using "the right tool for the job" ... get a set of indexing ratchet wrenches like this:
    http://www.homedepot.com/p/GearWrench-Indexing-Combination-Ratcheting-Wrench-Set-12-Piece-85488/204621316
    It will cut the job time in half compared to a straight combo wrench.
    www.perfprotech.com/mercury-marine-parts-catalog/sea-water-pump-assembly/assembly/7585/270?model=784
    remove bolts form bracket pull pump a little forward then losing hoses.they are right under the motor mount
    that's a pretty pump!
    Its going to look good on my engine in the spring! Thanks for all the help and Hardin Marine
  • AlswaggAlswagg Posts: 2,326Member ✭✭✭✭✭
    Remember to use the proper pulley remover and installation tool. Do Not use a press.  These are special tools for this particular job.  Aka power steering pulley tool   Proper pulley alignment is cridical for long belt life
    Speaking of belt life...i have replaced my pump but do not have any if the fancy tools to get that belt tension to spec- same for cars for that matter...how critical is that tension and do the pro's really use those gauges? I understand to tight is a belt killer and to lose slippage...
    Yes use a tension gauge
    Simple devise I have had one for years
    Then I will invest- would hate to call sea tow for such a simple problem...I blew mine out when a water pump seized and I actually put an auto one on there on the water but did not realize the pump had seized until I put the belt on- it has held up but probably should get the merc one and put on it or at least have it on the boat. Thanks Al.
  • Dream_InnDream_Inn Annapolis, MDPosts: 4,764Member, Moderator mod
    Ras, a spare belt is also a good thing to have.  But I agree, tension gauge is a good thing.  Mine has a spring type tensioner that is supposed to automatically keep the correct tension on it.
    now that I think about it, mine does too.....? 350 MPI horizon....it was a while ago...
