TV and TV antenta
I had a thread going on TV selection and I think I understand much better what I need so I'm working on resolving that before my upcoming hopeful Thanksgiving week of boating- when I look at the specs of the TV's they go into a buch of stuff I don't understand about the reception oms and amps and angle of the dangle- is there anything special about a TV and antenna match up? Also, why do we always capitalize TV?
Best Answers
Cableguy Greg Member Posts: 5,048 ✭✭✭✭✭
As long as you have a digital tuner in the TV, you will be in good shape. A 12VDC TV would be ideal, but you can get a 120VAC TV and use an inverter or generator to power the TV. You don't need a "digital" antenna. As long as the antenna is a VHF/UHF antenna, it will work.
Go Steelers!!! -
Here is the antenna that I would buy...
http://shakespeare-ce.com/marine/product/3015-seawatch-hdtv-antenna/
It should be a direct replacement to the one that you have.
Go Steelers!!! -
Liberty44140 Member Posts: 4,414 ✭✭✭✭✭
The guys on my dock with newer boats have Glomex TV antenna's. I dont know if they are better or not. I have the Shakesphere and I get something like 20 digital TV channels with the digital converter box. I'll also be upgrading the TV this year but will keep the same antenna as it works fine.07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV) -
LaRea Member, Moderator Posts: 7,875 mod
Mr. Language Person says: we capitalize TV because it's an initialism (an acronym in which you pronounce each letter individually). The caps help distinguish it from a normal word.
But if Ras prefers tv to TV, I say it's no BFD! -
rasbury Member Posts: 8,560 ✭✭✭✭✭
Thanks @Cableguy Greg and to everyone else's comments as well! That was the one I was looking at and just bought off amazon for 83 bucks so it is on the way! On to the TV. -
Thanks @Cableguy Greg , I will push on. I did notice that the old box has two power wires, new one has an a plug in only and it says 12 v / 120 or maybe 110, electrical stuff just does not process well with me.. The old box does not have any plugs but us hard wired to shore and battery I suppose... -
You're welcome!!!
The booster you have should work just fine. If it doesn't, it is because the amp is in the new antenna and the power supply that came with the new antenna sends 12vDC to the antenna for the booster that is in the antenna to work. Looking at the instructions via the interweb, you might need to install it. I would try it with the existing one, and with good cable connections to see what you get. Do your best to make sure it is a straight shot the to the antenna and there are not any splitters between the antenna and the booster. Between the booster and the TV, a splitter is okay to have.
No matter what, you need good clean connections. The screw on connectors that come with the antenna are okay. I prefer compression connectors. We use PPC and Digicon branded connectors where I work. I have found that the Snap N Seal, or Ideal brand compression connectors at Lowes or Home Depot are good connectors.
Thanks again Greg- I'm sure this stuff is simple to you but it is like me trying to read a book in Japanese.....
