Water in my hull near AC unit in aft cabin
I have water in hull that seems to be too low to make the bilge pump work. Right by AC unit in floor. I vacuumed it out and dried it and doesn't seem to be any problem but is this normal? First picture is vacuumed and dry after.
the condensation drain was clogged on mine and dumped water in the bilge.
@gtyee, is that water up in the bow or back at the stern? I can't remember there ever being water in the bow of the boat under the front berth area? Is a drain hose loose?
I have often vacuumed water out of the stern of the EC 310 and 360 that the bilge pumps couldn't get from rain or backwash or just draining from cup holders etc. I have been told lots of times that was just obsessive on my part but I had a small shop vac so I did it.
But I can't remember there ever being standing water in the bow.
The water is by the bow under the rear berth( under helm) but it seems the water would need to rise to set off the bilge pump. Stern had a little water that I vacuumed up.
That water looks murky like it's been sitting a while. It's not normal to keep taking on water like that. It should stay dry. Try and find out where it's coming from.
@gtyee you mean it is in the bow in a compartment accessed by the front berth....that is - when you lift up the mattress of the front berth and the access cover for the AC? Sorry to be so picky but I'm trying to place the location exactly in my mind in order to be of some help!
I agree with Mark if the water is up under the front berth: 1. It shouldn't be accumulating there so 2. something is leaking and it can't drain to the back bilge area or 3. if there are some leaks there normally, then the bilge pump is definitely not doing its job and is misplaced.
Question for me is WHAT could be leaking into that area?
Here's what comes to mind: 1. either fresh water supply hose from the HVAC pump to the HVAC unit is leaking there should be double clamps top and bottom (loose clamps/damaged hose) 2. the spent water hose from the HVAC to the overboard through hull fitting is leaking there should be two ring clamps on this through hull fitting and there often aren't again or (loose fitting/damaged hose) 3. plugged AC drain pan hose fitting or hose not draining fast enough during heavy (normal) use and the water is sloshing over the pan edge. 4. water is entering the hull via a loose fitting to the through hull fitting and water is getting into the boat. 5. Does the anchor locker drain overboard on the EC 310 or is a hose just loose in the bilge?
I'd exhaust looking for loose hose fittings, poor drainage and probably end-up moving the bilge down.
FOR SURE I'd call Rinker and tell them its a 2013 Rinker EC 310....the model that won a bunch of awards. Out of respect for their boat and your purchase.... give you some suggestions. Geez! I wish I lived closer!
BTW make sure some friggin spider hasn't built some Fort Knox in the drain vent!
My water was from ac hose that had no clamps on it. Double clamped it and dry as a bone since
