Bad reading on the tachometer...
Lake_BumLake_Bum Member Posts: 934 ✭✭✭✭
My boat is a 2000 Captiva 232, with the 350mag and Bravo lll outdrive.  I had very irregular readings on the tach when I test drove it.  I ended up buying it, and had to winterize it once I got home, so it's tucked away for the winter now! I was getting readings off the charts according the the gauge, as in buried above 6000 rpm's even at cruising speeds, and from my speeds, and sounds on the motor I would guess it at 2800 "actual".
Any clues as to how to address that issue, once spring rolls around?  The readings were normal at idle, then would be all over once on plane.......
