Captiva 196 Fender Pfender Pro Cleat
Just bought a 2012 Captiva 196 Bowrider. I want to fit two Pfender Pro (fender) Cleats above the rub rail. To do this it would be great if I could remove the bow seat backs to tighten the nuts once the cleats have been drilled and bedded. The seat backs seem to be very firmly affixed. Is there a reasonably easy way to remove them?
Dave
http://www.ebay.com/itm/Boat-Marine-Twist-Lock-Deck-Plate-4-1-2-Cutout-4-ID-ARCTIC-WHITE-O-Ring-Seal-/161913355614?hash=item25b2c9bd5e:g:adEAAOSwxN5WaLOw&vxp=mtrused
http://www.ebay.com/itm/MARINE-BOAT-KAYAK-CLOUD-WHITE-PLASTIC-INSPECTION-DECK-PLATE-6-OD-4-5-8-HOLE-/201681637507?hash=item2ef5299083:g:gfEAAOSwYIxX8W0f&vxp=mtr
Those deck plates are going to sit proud and make putting the seat backs back on difficult.....
Might need to simply clean up the access holes, seal the fiberglass edges with epoxy and let the seat backs be the covers. Obviously that means you need to make sure that the access holes are completely within the area covered by the seat backs, but you would want to do that in any case.
Dave
