Maintenance Time
davidbrooks
Member Posts: 1,418 ✭✭✭✭
I have a 03' 342 with a Kohler 5kw generator. At the end of the season it was getting pretty hard to get started so i am thinking it is time for a tune up. Winterizing it was interesting. Had to pump the pink through just using the starter. So I went looking for a few videos or how to discussions and didn't find much. My first question is if there are any suggestions to getting the sound shield off so i can get to the motor? Front comes off easy enough. So for a tune up i was going to get the GM48014 Sea Spares Kit, Kohler ECD that includes:
I looked though all the manuals and they weren't helpful at all. Thanks in advance.
- Brushes # 239282 (2)
- (5) 223316 - 10 amp fuses
- (5) 358337 - 10 amp fuses
- (5) 283645 - 15 amp fuses
- (5) GM39266 - 20 amp fuses
- (5) 262389 - 25 amp fuses
- Fuel Filter # 267987
- Oil Filter # 359771
- Impeller Repair Kit # 359978
- Spark Plug # GM46180 (2)
- Zinc Anode # 260085
For parts, I can highly recommend:
http://www.partsfortechs.com/asapcart/generator-parts-kohler-c-14_83.html?zenid=130b5fe16b522d563e5726a524f4bcbb
Personally, I would not over spend on that kit. It has a lot you may never use. Plugs are an NGK BPR-4ES. Don't use the engine s/n to get plugs, you need the long nose ones (engine s/n will get you short nosed ones).
Impellor good to have a spare. There is a small coupling behind the pump worth changing and having a spare.
My .02 on this: the fuel filter at the fuel
pump is a pita to change. I replaced it with just a threaded barbed fitting and use the in-line filter
the anode is worth changing, then just keep an eye out on it.
You can service the plugs without taking the whole cover off. Remove the front right screw on the top. On the engine end of the cover, 2screws on the end and that panel will pop off. You can tilt the cover back then to get to the rear plug. You can check the coolant in the reservoir and clean the spark arrestor too.
An easy check for starting issues too: pull and clean the anti-diesel valve off the carb. Clean the hole too with carb cleaner. It will be facing you as you look at the carb side and it has one (1) wire going to it.
Good luck!
I litterally lay on top the sound shield to change the impeller.
