Installing Fishfinder/GPS
Hi everybody!,
New owner here... a 2004 232 BR. I have been lurking for a while. Trying to use all the great info to not pester you guys. (But noticed little discussion of FF Installs.
Like many here, the depth/speedo don't work so solving with a fishfinder/gps (Which I wanted anyway
2 questions.
1)Where is best place to tap into for power. (I'm not super electrically savy, though I did this years ago on my old boat, but don't remember anything more, than that I tapped into some existing wire at the helm.) Any tips on which wire to tap into or what else I need to do)in line etc.) would be awesome! (in case it matters, the FF is the Lowrance 5 DSI)
2) I was of course planning on small hole "above the water line" through hull, right below extended swim patform to route cable through for transducer... mentioned this to my wife and she and my girls insist that they think that the water line is right there just below the swim step... and thinking about it, this is close to true. (Is this normal for this model?) I had thought about the fact that it must be adding extra drag when we are running.
Oh, and I guess I should ask, any hints tips for this model on snaking the transducer cable up to helm? I hadn't looked closely yet at wire paths, but man is everything tight for space and wire lengths under dash!) (Have a couple stereo issues and it's hard for my "chunky" 6"4 build to get under there and look at stuff.
Thanks in advance for any help/advice you guys can offer! I see that this is a great community already from lurking!
Scott
So I'm not sure if that changes whether you want to put the hole above the drive. Transducer placement is important, so start there.
However as Kysean said through hulls are actually a very good option. If installed properly they work better than transom mounts. This is because the entire hull of the boat can now pick up the sonar signal as the transducer becomes one with the hull. You do have to carefully install them and ensure no bubbles when the transducer is mounted down, but if done right they are great.
I'd think about that as an option.
Scott I had a look at some pics of my transom mounted transducer. See below. It's pretty close to the drive. I can track bottom pretty well, but I think if I placed it a little more to the right, I would actually be able to pick up fish schools at higher speed. Anyhow, take a look at youtube to get some good ideas about where to install the transducer IF you stick with transom mount.
My guess is that hole is around 3 - 4" above the water line.
That's the reason why they want the cable to run straight up and tight. Also the eyelet locks the cable down so it can't pull through from the engine compartment and go into the drive plus open up the hole in the transom.
By the way make sure your transducer is level with the waterline, not how the boat sits right now. If it isn't level with the waterline you will get half scans of fish arches on your sonar screen.
I also have a ram mount for my fishfinder at my helm. They are great.
