Engine will not start
hello all
would be grateful for some help before I have to pull in the diagnostics man. Volvo Penta 5.7 300hp 2010 fuel injected, worked well then moored up for 6 weeks and now won't start, checked spark OK fuel Plenty of it getting to cylinders battery spinning engine perfectly but no sign of it firing up at all. I'm at a loss to what could be causing this? Maybe sensor for crank? Can anyone help please.
Bazza
Bazza
I recently had the same problem and turned out to be water in the gas tank, the seal on the gas tank cover fail and when it rained water found its way inside the tank.
I suggest start by checking the electrical system and work you way from there.
cheers happy new year Bazza
