Questions
I have 3 questions about my 2006 250 Express Cruiser with the mag 350. Today I took her (in perfect conditions) from Boston to Marblehead - about 45 mins. Each way.
1. What speed should I be at around 3800 rpm (I'm around 24)
2. What engine temperature? I'm at 175
3. Lastly I noticed something new with my hot water (fresh water) tank. Usually it heats both when plugged into shore power and engine heat when running. Today, after the extended run, I had no hot water. However once back at the dock and plugged in the hot water came back. Ideas?
Thank you all in advance!
As raybo says mine is always super hot when I run my engines.
