2005 Rinker 270 fv cooler spot replaced with cabinet door and Led stip lighting
Hello ROC members,
Here are two small custom projects I have completed. First in an effort to utilize the space behind the cooler storage bin and eliminate the small ice melter cooler, I changed out the bin spot under the cockpit sink and added a cabinet door. I used boat outfitters to buy the door which turned out to match perfectly with the battery switch cabinet. See link here:
http://www.boatoutfitters.com/king-starboard.html
I also added the led strip lighting to the cockpit, cup holders and cabin . As of now they are all connected so the color is synced throughout. I have them powered off the accessory switch. I took the oem plastic cup holders and turned them into led cup holders. I used a countersink bit and drilled a 1/2" hole and ran the strip light through it. In addition to the 3m tape on the back of the strip lights I used clear silicone to secure the lights to the cup holder and to fill in the hole. I figured if it turned out poorly I would be replacing the cup holders with the led ones anyway. So far I am totally happy with the results and low cost. I have less than $50 total invested. I ordered everything off Amazon.
Anthony Price
The Price is Right
MacRay Harbor, Harrison Twp., MI
The Price is Right
The Price is Right
Thank you for posting this up, it answered a few questions...
1. was can you just cut the wire to the power brick and plug it in (since they all say 12 volt)
and
2. Wondered how well those extension wires worked..
Interesting idea about the door.
Diggin - any idea if you can measure the size of that door?
Ordered these:
https://www.amazon.com/gp/product/B01IHDYYFS/ref=od_aui_detailpages00?ie=UTF8&psc=1
These are dimable and have two white LED's that can give you the "warm white" color that normal light bulbs have.
I personally find the 3 lights that come standard in the 2004 270 cabin to be pretty useless and ugly..
Video:
http://tinypic.com/r/28so2rl/9
In the above picture you can see the sensor for the remote up top and then almost everything is hidden behind that wall.. the things on the bottom are a 1 to 4 way splitter. See picture below.
I bought a 1 to 4 way because I wasn't sure how many strips I am running. Right now I think above and below the top shelf is good enough...might add another row on the underside of the back rest in the future..
I did end up filling in that tiny part up front next to the mirror:
I love how it came out. It was a little pricey but I figure I can always stick the cooler bin back in and take the door for the 340 or 342 I feel is in my future. There are a few other door companies online but boat outfitters matched oem perfectly.
The Price is Right
http://www.boatoutfitters.com/build-your-own-custom-starboard-boat-door
Yes the 49ft extension wire was enough for my application I cut the wire off on the 12 volt side of the transformer because i was using 12 volt and not 110v. I wired it to my accessory switch from there. I cut the male 12 volt jack plug off the 110 transformer and plugged the male jack end into the controller and hard wired the other end to the switch. the check marks show what I used in the picture and the red slash show what I didn't use. Hope this helps.
The Price is Right
@Dream_Inn I havent had that issue but use the remote with 10 to 15 feet and haven't tried any further out. Not sure if that has anything to do with it cutting out.
The Price is Right
