2005 Rinker 270 fv cooler spot replaced with cabinet door and Led stip lighting
2»
  • onislandtimeonislandtime Member Posts: 309 ✭✭✭
    Is this looped or can it terminate?
  • ApriceAprice Member Posts: 125 ✭✭
    It can end where you need it to by ending with the strip light.
    Anthony Price
    The Price is Right
    MacRay Harbor, Harrison Twp., MI
  • Dream_InnDream_Inn Member, Moderator Posts: 7,799 mod
    @aprice It doesn't have anything to do with operation of the remote at a distance, I think it has to do with having more than one strand of lights tied in both parallel and series, thus drawing a bit more current (and power).
    edited January 2017
    Aprice said:
    Hello ROC members,
     Here are  two small custom projects I have completed. First in an effort to utilize the space behind the cooler storage bin and eliminate the small ice melter cooler, I changed out the bin spot under the cockpit sink and added a cabinet door. I used  boat outfitters to buy the door which turned out to match perfectly with the battery switch cabinet. See link here:
    http://www.boatoutfitters.com/king-starboard.html
    I also added the led strip lighting to the cockpit, cup holders and cabin . As of now they are all connected so the color is synced throughout. I have them powered off the accessory switch.  I took the oem plastic cup holders and turned them into led cup holders. I used a countersink bit and drilled a 1/2" hole and ran the strip light through it. In addition to the 3m tape on the back of the strip lights I used clear silicone to secure the lights to the cup holder and to fill in the hole. I figured if it turned out poorly I would be replacing the cup holders with the led ones anyway. So far I am totally happy with the results and low cost. I have less than $50 total invested. I ordered everything off Amazon.
    What color door did you order to match? I see they have 2 whites? I don't suppose you remember the cutout dimensions? Looks like 20 and 3/4 ? I assume a square opening? Boats put away and I can't easily get to it :(
    @tniggel, check out the door!!!
    Anthony Price
    The Price is Right
    Color is Artic White and 20 3/4 square.
    Anthony Price
    The Price is Right
    @J3ff do the lights cycle or do you manually have to change the colors?
    Boat Name: Knot A Worry
    Aprice said:
    Thanks!!
  • J3ffJ3ff Member Posts: 4,170 ✭✭✭✭✭
    Either one. You can control manually, or it can do variations of cycling.
