trailer tires
last year I had a BAD season, 3 blowouts in about 2 weeks, tires were 2-3yrs old, so I'm looking at new tires since I have 3 different tires, also going up to a 10ply. what tires do you guys like and why? some tire I see say to inflate to 80lbs., do you inflate to that or do you inflate a little less, say 77, 75 or even 70lbs? I have the trailmaster heavy single axle for my 212 rinker captiva which is 3500-3600lbs with no fuel. any info will help greatly! thanks!!!
Always try to run E rated trailer tires, at or near the max psi
i use MAXXIS E rated. i was able to get them shipped to pep boys for free and i just picked them up and had them mounted by a friend of mine.
Note that the "born on date" in only required to be on ONE sidewall and not both so if you don't see a date on the outer sidewall, it'll be on the inner side wall.
Because most trailer tires sit in the sun, they will degrade much faster than tires that sit in a cool dry storage shed. Consider buying a set of tire covers - they do actually work to keep the sun's UV rays from rapidly degrading tires.
Lastly, the brand of tires you buy will make a big difference in longevity - I also use the MAXXIS trailer tires for my triple axle trailer - read a lot of reviews and they seem to be one of the most recommended.
