Amazon FireStick Powerboat TV??
diggin2day1
Member Posts: 1,331 ✭✭✭✭
Is anyone able to get Powerboat TV or shipshape TV on their jail broken firestick? I'm new to this thing!!
You need a good solid WIFI signal....I would be very careful about streaming from your network unless you have an unlimited data package. The stick I use at home is hard wired into my router. Wireless, especially when shared at the dock by numerous other boats, and at peak times during the day and evening, may not provide you enough signal to stream uninterrupted.
You also need a dedicated 110v socket on your boat to plug the stick and TV into.
You need a smart TV.....with a USB port in the back.
It can be done, but unless you have a 12v converter to run that TV and stick, you will only be able to use it when power is plugged in at the dock or when you are running your genny.
