Engine wont crank and purple coil wire starts smoking hot when ignition turned on
TimSImpsonTimSImpson Member Posts: 11
I assume it is a ground issue but if anyone has a wiring diagram or suggestions that would help..
I already checked the ignition switch and the starter and slave solenoid.
Thanks
89 V170 3.0 mercrusier with Alpha 1
