Port trim tab not working - where would you start?
J3ffJ3ff Member Posts: 4,162 ✭✭✭✭✭
Have the standard trim tab switch with the LED's.
- When I got the boat they both worked, verified out of water and in water...
- When engine was replaced, got it back and realized the port trim tab no longer worked, the one all the way up led still lights up, but the tab does not move and the other led's do not light up
- Stbd tab and leds work like normal.
Usually a fuse is the first place, but I'm assuming it's one fuse for both tabs right? Where would you start on this one ?
Best Answers
