Suggestions for raising the seat height when needed
My 232 Captiva came with a non-bolstered seat I'm constantly having to stand up to get a good visual and I was wondering if there's anything that can be added to the seat post where is the seat could be raised or lowered we needed does anyone have any suggestions for that? I have currently been using a throwable floatation device which tends to slip and slide around and it is still doesn't raise the ceiling height a quiet enough I have A desk chair at home that has levers on it that when you rise above the seat you can pull lever and it raises the seat up or you can push the lever and the seat will go down and you can adjust the height anywhere in between which would be awesome if I had something like that in my boat but the supporting mechanisms on the desk chair aren't nearly as big as the seat post in the boat so they will interchange I've already checked into that.
https://www.amazon.com/Wise-8WP21-18S-Adjustable-Boat-Pedestal/dp/B001603LD6/ref=sr_1_1?ie=UTF8&qid=1484107970&sr=8-1&keywords=adjustable+pedestal+boat+seat
