Storing propane cyls?
BellevilleMXZ
Member Posts: 732 ✭✭✭
I bought a BBQ this winter ........something I was thinking about, is where do you store the cyls? If BBQ is mounted and off, in it I assume. But what about with BBQ stowed away when under way?
My problem is were to put the grill, I have the magma 15 inch kettle grill, the only place I can get it to fit is in engine compartment. Then bungee it so it does not roll around, and get against the belt. It's a pain to get in and out. once I put in a plastic trash bag then put it behind stairs on the bed. was not crazy about that idea either.
Any ideas?
Hmmm, I think she'd be hired in our marina for a lot of boats!
As far as propane, just make sure to always twist the switch off the bottle when you are done. You can very easily have something push the button down and turn the gas on. There are bags that hang on the back of the boat that hold the propane. I store mine under a seat in the cockpit.
@randy56, I use foil to catch the drippings. Then when I am done, I throw the foil away before storage. I do have the Newport model, which is rectangle rather than a kettle. The nice thing about the storage bag is that it catches all of the residual grease and it is easier to clean. You could even line it with some paper towels.
@Cableguy Greg couple questions, Where are you putting the foil on the inside of the grill? does it smell when you put it under the bed, as we leave the bed up all the time also. Is this picture the type of bag/tote you are referring to?
@reneechris14 Do you mean you paid $150 for the tote?
