Should my engines be using oil?
I have a 2014 310EC with twin Merc 350 inboards. I regularly check the oil and they are using a quart ever 50 hours. Is this typical/correct???? I run a lot at 7.5mph and a lot at 28mph. I try and run them at WOT for a couple minutes every time I go out as well.
2014 Rinker 310 Express Cruiser.
I would say some oil consumption is going to happen...what's normal is hard to say. 1 qt in 50 hours doesn't seem too bad.
1 quart every 50 hours for both or each engine? For both, that isn't bad. These engines do burn some oil, especially when you are loading them. You'll see consumption go up if you have a heavy load, or are +80% of WOT.
A quart every 50 hours per engine would be a bit higher than normal ... but again if you are regularly hauling 10 people and stuff ... you can get higher oil consumption.
