Pin-striping
I have two layers of white pin-striping where the top of the blue gelcoat meets the white gelcoat. It has started to wear away in a couple of spots where the previous owner had his bumpers. I ASSUMED that the pin-striping was added because the line, where the blue meets the white, may not be a straight and might be slightly wavy. In the two or three 2-inch spots that have worn away, the line seems straight. I'd like to remove the pin-striping but do not want to add it back. Can anyone tell me what the function of this pin-striping is? If I remove it, should the gelcoat line be straight? Thanks for your help!!!
Fin and Tonic (w/Lime)...
Rookie,
Nice looking Captiva! Love the blue.
To remove the stripes use a 3M eraser wheel on a drill. I just removed the pin striping on my 2004 GMC Yukon XL. You can get one at auto parts stores or go to Amazon for $30 - 40. It worked like magic. I was nervous and worried about residue, damage to clear coat, plus fading. Run drill slow so you don't burn spots. I used goo gone after using eraser, then used rubbing compound to help even out blems. Looks like stripes were never there. It works like an eraser on a pencil.
https://www.bing.com/images/search?view=detailV2&ccid=oSBD/thG&id=DE10C600FF624FBE6E224B13814A096C0DD7B384&q=3m+eraser+wheel&simid=608027981611401651&selectedIndex=0&ajaxhist=0
With gel coat on a boat you might need to use a buffer and heavier compound to hide where stripes were. Then determine if you want to replace the stripes or leave it and wax it!
Rob
