Help
martin1314
Member Posts: 36 ✭✭
I have just bought my first ever boat! A Rinker 265............ and now I'm looking for some assistance.
The boat came with a mangled prop and no cabin door so I'm looking for either new or second hand stuff.
Any help or information would be very much appreciated.
This is all very new to me so go easy on me.
Martin from Scotland
Best Answers
Stodge
Member Posts: 2,738 ✭✭✭✭
Welcome aboard and congrats on your boat purchase.
http://greatlakesskipper.com/ has a lot of OEM Rinker parts. You will want to check there and see if they can have a door. Otherwise you can try reaching out to your local Rinker dealer.
Take the prop to your local marine store. They can read the markings on it to determine the size (diameter and pitch) of the prop as well as see what it's made of (aluminum or stainless steel) and get you a replacement.
I hope you had a survey before you bought it. If you didn't I'd strongly recommend getting one. That will point out any issues you can see like moisture in the transom or stringers. Better to know your boat is seaworthy before you put her in the water.
Best of luck and keep us posted.
93Vee Member Posts: 86 ✭✭
Hi Martin and welcome to the board. It looks like you have 1994 Fiesta Vee. Congrats. It's a really fun boat and I think you will really enjoy it.
You may interested in looking in Forum Archives where a manual is posted for a 1993. The two vessels are very similar.
I agree that sending out the prop for a refit is a far less expensive way to go then buying new. If you have a Bravo 2 then it is probably a 21 Pitch.
As far as the door, it will be hard to find a replacement. I would consider using 2 Starboard 1/2 inch thick boards with a 6-8 inch hinge in the middle with a "U" shaped 4 inch door handle.
The manual (if you did not get one) has helpful schematics for a new boater as far as the pluming and location of items in the engine compartment.
Good luck and ask a lot of questions. The guys and gals on the RBO are very knowledgable and are always willing to help
Cheers!
randy56
Member Posts: 4,085 ✭✭✭✭✭
If you repaint the outdrive on alpina, this is a good product.Boat Name :
If you can't find an OEM cabin door you may want to contact a local glass shop that does Plexiglas. That's what I had to do with my old Bayliner as they didn't have stock of the door anymore. The shop actually made 2 doors because they had to buy the whole sheet of plexi.
A slightly inebriated large person got wrapped up in the door as I shifted to neutral one night and my cabin door ended up in pieces. No one was hurt but it sure was a good laugh until I saw that it cost around $200.00.
The replacement door is going to be a diy job so wish me luck lol.....
I'm going to get "Alpina" cleaned by a company over here as the seemingly bring the whole boat back to new!!!....... any thoughts on cleaning it as I was thinking about giving it a go myself?..
Ps, I've never had a boat in my life so this is all very exciting........ (my knowledge of boats is the front is the Kate Winslet end and the back is, well just the back lol)
Martin
The prop is alloy and 21, I've sent off some pics the see if it's repairable so fingers crossed.
The door is a problem as I've been in touch with Ginger at Rinker and she put me onto great lakes but they can't help........ as for Rinker dealers over here they are only interested if your buying a new boat!......... its going to be a diy job so wish me luck.
Ps, the boat doesn't have a name at present so she is going to be called Alpina....... which means "Scottish Blonde"
For the exterior, just wash the boat then use 3M Imperial compound and a wool pad with a high speed buffer. It brings the gel coat back right away and is easy to use. When that"s done, put on a good carnauba wax. Youtube has some good videos on the subject.
Please take some pics along the way so we can see the Scottish Lass in all her glory!
Martin
