Getting these winter projects wrapped up...
Finally got the new cockpit tv mounted...(remember the old flip down one ? It looked like it was mounted to the headrest of a '72 Country Squire wagon!) had to run a 110v receptacle for power, but a pretty clean install overall. This one is white and has a built in DVD player. Flips up out of the way and swivels.
Bring on the warm weather !!!!!!
I do like the looks of the TV mount. I'll have to give it some thought over spring. I'm not sure how much we'd use a TV up top, but maybe once it's there we would. I see you have the antenna cable, so I assume you used a splitter in the hardtop off the antenna?
Those props look beautiful!
Good point liberty, if I put a TV up top I'll have to run the cable from the amplifier which is in the front berth.
I'm with you Dirty, I don't use my front or rear berth TVs except for a DVD here and there.
so are you guys saying that the Shakespeare radio antenna will receive a TV signal?
thanks for keeping an eye out for me... This is a tough one for sure
