new dash for 2006 270 FV
Mercury2005
Member Posts: 141 ✭✭
Installed new dash panels, switch covers, compass, steering wheel, vhf radio, refurbished Faria gauges, added a USB plug.
More stuff to follow, stay tuned
Panels came from:
Sam Sladon
TECNOGRAFIC, INC.
1010 NW 51st Place
Ft Lauderdale, FL 33309
www.tecnografic.com
gack, you panels look great and I'm sure a lot less expensive then mine.
The new 5 hole panel is 1/8" material and is 'flat' so no recesses for the gauges, but it does bend to fit the dash contour. I had Sam add two extra mounting holes dead center so I could make sure the "curve' fit the dash. I had to install a couple pieces of 1/4" starboard in the dash to have something to screw into and it worked out OK.
The switch panel being flat was no problem, the switches fit great and the screw holes lined up. I had Sam add another hole to install a USB port next to the 12v outlet. The circuit breaker panel is also flat and the breakers fit perfectly and the holes lined up, although one hole had no place to screw into, will need to fix later.
The last panel was the key switch panel and it also is flat and came out perfect.
The last item was the radio. The original radio had a bezel that screwed into the dash and the radio mounted in the bezel. The new radio is bigger and mounts from the rear. I had Sam make an adapter that will mount to the dash with 4 holes just like the original bezel and the radio will mount to that new adapter so the radio can be removed without having to remove the switch pane.
I know all that stuff was expensive but IMO was well worth it.
Appreciate all the feedback from you guys and look forward to seeing your mods.
