Dockside Water Inlet
ruwallydog
Member Posts: 92 ✭✭
Towards the end of last season the admiral informed me we didn't have good water pressure from the sink on the boat. Checked/disconnected the water coming from the dock & water shot out like a fire hose.
So so I cleaned the intake screen...reconnected the water and it seemed to be better. Then went to the boat the following week and had the same problem again!!
Do those inlets go bad? Should I just replace or is there a fix?
thanks
thanks
I had a crack in the original and replaced with a stainless one 6-7 years ago...which maybe means it's time for a new one.
My suspicion is that the problem lies in the water pressure regulator inside the dockside inlet but that's not much more than an educated guess.
As suggested I will go ahead and order a replacement for the dockside connection and replace in the spring. Like the idea of blowing out the lines as I will have it all apart then anyway. Can only imagine what's in there after 16 years!!!
Thanks for the help!!!
