Fuel Consumption vs. Cruising speed/rpm
Willhound
Member Posts: 4,236 ✭✭✭✭✭
Getting closer to sea trial/delivery of our "new to us" 2000 FV270 with Mercruiser 5.7L EFI with stock BIII drive. Curious of real world examples of what to expect for fuel consumption vs. a reasonable cruising speed. To me, reasonable means on plane with just enough throttle and tab in to keep it there. For example, with two people aboard, half a tank of fuel and water tank topped up, what RPM/Speed/GPH should I be looking at. Searched several different ways on this forum, and few others, and although there are a few charts and that animated fuel consumption website, I don't see how they relate to a particular hull, weight etc.
Is there a chart or something someplace that I missed? Any anecdotal examples?
Best Answers
diggin2day1
Member Posts: 1,331 ✭✭✭✭
My VesselView says that I'm getting 12.6gph while cruising at 28mph at 3500rpm. FV270 with 350 horizon and Bravo 3... 22p props.
Willhound
So after 3 full seasons I'm reviving this thread to somewhat answer my own question.
I never could find a fuel graph for a 2000 Era FV270 with 5.7L EFI Gen+ but for the last 3 years I've tracked my fuel consumption and hours. My engine isn't VV compatible or I'd have it and I don't have a fuel flow meter. These numbers are an average of all hours run, so everything from idling at the dock to full burn. But most of the time I'm on plane at between 3400RPM/24mph and 3600RPM/27mph where the engine seems happiest and I can easily stay on plane with 2 to 3 adults, full fuel and water and gear. My "seat of the pants" makes me think that this is likely the sweet spot for max GPHvsMPH although I'd be happy to be proven wrong. I have been toying with the idea of running at another 200 RPM or so higher the next couple of tanks to see if it makes a difference better or worse.
My average over the 3 years has been 23.54 LPH or 6.22GPH. Wherever you see Gallons in the attached I've converted to USG, not Imperial. USD figures were converted using an average exchange rate over the last 3 years of $1.30CDN to $1USD. Average fuel cost per hour of $32.55 CDN or $24.54 USD. The first row entry is from the day we picked up the boat and filled it on the way to the lake. That fuel is not included in the averages.
I fill to full every fill up. For better or worse I don't believe in running around half empty and filling up around here is often a hassle so when I fill, I fill.
For all you numbers junkies out there like me.
http://rinkerboats.vanillaforums.com/discussion/4295/2005-270fv-cruising-speed-rpms-etc
For example, boattest.com tested a 270 with the 6.2 and found that she could cruise anywhere from 23 to 34 MPH without losing more than 15% compared to the "best MPG" speed of 27 MPH.
Most Rinker express cruisers are like that. Once you are on plane, the fuel consumption stays pretty flat until you get near wide-open throttle.
But does no one own, or have owned that series FV270 with the 5.7 EFI 260 hp that can say, "I found that at around xxxRPM and XXXspeed I was averaging around xxxGPH? Although I'll be new to cruising, every boat I've ever owned had that certain speed/RPM where the ride was comfortable and the GPH was about the best it was going to get, for that speed. Obviously the best GPH any boat will ever get is either sitting at the marina, or at idle, that's not what I'm talking about. But in the real wold that information I'm trying to find must exist, just can't seem to find it. I'll keep looking.
i own a 270 with a 5.7 GXI
http://www.boat-fuel-economy.com/volvo-penta-3.0-gl-135-fuel-consumption-us-gallons
Cheers!
Partly why we kinda worry about fuel consumption here...
