Maintenance of new (used) boat
gack
Member Posts: 315 ✭✭✭
I picked up m 270FV from a broker a month ago and I'm trying to determine what engine/outdrive maintenance I should perform on it before I put it in the water. I don't have any history of the boat but it looks like it may have a new outdrive (see pic) and fresh bottom paint. Props need reconditioning. Engine ran good during survey but I was unable to do a sea trial due to distance to water. What do you folks recommend?
I don't know much about reconditioning props, but yours need it! I hope they can be saved. New outdrive -- lucky you!
I thought I could save a few $ and bypass the outdrive service since it looks like a new one was put on, but probably best not to chance it since I don't have history on the boat. I also have a Kohler 5E Generator and AC. Thinking I should change plug and impeller on the genny. Will check thru hull fittings, swim platform is solid.
