2003 270FV odor when hot water is turned on.
II have a 2003FV and when I turn on the hot water valve in the sinks it smells horrible! does any one know how to fix this?
Had a similar issue on my sailboat in the Bahamas when I filled up w/o and added chlorine.
You need to flush it real good. First I'd fill it with heavily chlorinated water or even white vinegar(this is what I used). Take a ride and let it swish around in the tank, then drain and flush till clean.
Always add chlorine or a fresh water treatment to your water. It's a little extra work, but drain when not used.
Good luck.
mine was bad when I bought the boat and i flushed with a good amount of bleach at first. I now put a few little chunks of pool tablet in the fill tube at every fill. we dont drink the water so it just keeps it fresh enough.
