Smoke and CO2 Detectors
Willhound
Member Posts: 4,221 ✭✭✭✭✭
Looking at purchasing smoke and/or carbon monoxide detectors for FV270. Currently none on board when we surveyed the boat . Interestingly, a search on the forum came up zero on smoke detectors. I guess just commons sense that everyone has one?
I was going to go with a combo unit to save some $$$, but thinking about it, I think I'll go separate, that way if one goes off, I can tell which one, and if a unit fails, I can just change the one unit.
Also thinking of a CO2 with digital readout, that way I can monitor to see if anything at all is building up, not just when it triggers.
Good thinking??
Good thinking??
Best Answers
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
I believe that CO not Co2 is what you mean and CO(carbon monoxide) builds up down low thats why they are mounted lower in houses if my memory is correct -
Cableguy Greg Member Posts: 5,052 ✭✭✭✭✭
On my 280, I have the MTI Industries 65-541-WT surface mount 12VDC hard wired CO detector. You can get them in the hard wired or 9v battery powered. MTI makes them for RV's and boats.2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes"
Go Steelers!!! -
randy56
Member Posts: 4,085 ✭✭✭✭✭
My boat did not have them either, I purchased it at Lowes. Same as you would for a house. Battrie operatedBoat Name : -
rasbury
Member Posts: 8,694 ✭✭✭✭✭
Not true handy - we were running with full enclosure with the screens open on the back and the sides, slow speed and apparently pulling engine exhaust back in the bat. The kids were in the cabin which the windows were closed and mine went off. Everyone need to have them. -
I had the same issue when I was boating in October. I had the glass up and the back was open. I wasn't going very fast and the CO alarm started screaming at me. Every boat should have one, not just genny boats.2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes"
So for that, I think I'll just throw one in
It is completely false that you only need it if you have a generator. There are certain areas of the country with weather conditions that can come together to cause problems when OTHER boats are running generators.. We have one island where I am that creates a bowl at low tide... and if people around you are running them on a day with no wind, you're at risk. Gotta with two because of what was said earlier, gotta have a backup!
