Trim Tab Failure
Hi there, just bought a used 2002 Rinker 270 here in the UK, however, one of the things that came up on Survey was that the Port side Trim Tab failed to operate. Strangely enough, another 270 in my marina has exactly the same problem. Coincidence or has anyone else had the same problem? Before I call out an engineer, if anyone can offer some advice on where to look, it would be greatly appreciated.
http://www.ebay.com/ulk/itm/251417204000
06 Rinker 270
When I removed the old rams, I just cut the wire at the ram and removed them from the transom. When I installed the new wires, I used 4200 to seal them at the transom holes.
Just to see what was inside of a ram, I disassembled one. I will post pics later of what is inside a ram. I plan to reassemble the one ram, install new wires with new water tight fittings on both rams and test.
The rams, tabs and wiring will be for sale, so if anyone is interested let me know.
