Proper voltage readings
Hello All, I recently purchased a 270 and was making some repairs. Replaced the fuel sending unit and compass. I noticed both read about 5 volts on a voltmeter (light on compass and fuel sending unit). Is this normal or should it be reading 12v?
As for the fuel sender, you should be reading resistance across the studs(as the float rises/lowers the resistance changes)
