Looking for manuals
82Rinker82Rinker Huron, OHPosts: 3Member
We have an 82 15' Runabout bowrider. We've had her in the water the last two summers and are working on cleaning her up and replacing parts, there were no manual included. Does anyone know a good source to get a manual and a manual for a 1973 Mercruiser outboard motor? We also have some problems with the steering it is very hard to move the steering wheel but not having a manual on any wiring diagrams is a problem. Any help or directions would be appreciated. Thanks in advance.
  • randy56randy56 Newburgh INPosts: 2,475Member ✭✭✭✭
    try this link on the old merc. don't know what HP you have. The steering cable probably needs replaced.
    http://store.oldmercs.com/category_s/1651.htm
    Boat Name : Knot My Prolem
    2003 - 270
  • Handymans342Handymans342 Posts: 7,294Member ✭✭✭✭✭
    There is not really a manual for the boat.
  • rasburyrasbury Sanford, FLPosts: 4,950Member ✭✭✭✭✭
    check on E Bay also....sites like that. I'm sure it is out of print a long time ago!
  • davidbrooksdavidbrooks GermantownPosts: 473Member ✭✭✭
    Parts diagrams and break downs can be found if you search using your motors serial numbers.  Wiring diagrams.. are almost not helpful as there are so many options that I have yet to find a wiring diagram that matches how my boat was put together.  I end up just tracing the wires myself.  Sounds like you are looking for a service manual.  http://www.ebay.com/itm/like/182465990913?lpid=82&chn=ps&ul_noapp=true.  If you are just looking for parts.  Then you likely don't need this.
