prepping and painting outdrives
Ransnan
Member Posts: 81 ✭✭
Getting ready to paint my Bravo 3 outdrives for the first time, we bought the our 2003 342 last spring, and it was already painted, whats your tricks and tips for cleaning and painting? i want to try and avoid those pesky Barnacles as much as possible.
Best Answers
Optionsreneechris14 Member Posts: 3,134 ✭✭✭✭✭Zinc chromate for bare aluminum and outdrive paint for non ablative,don't use bottom paint on your drive.2005 Rinker FV342 Pawcatuck river,Ct
OptionsHandymans342 Member Posts: 10,375 ✭✭✭✭✭You guys are wasting your money on the Merc black. Just use Rustoleum
OptionsDream_Inn Member, Moderator Posts: 7,562 modHandymans342 said:You guys are wasting your money on the Merc black. Just use Rustoleum
I buy one can and get at least 5 years out of it. Not exactly the most expensive boating item I buy. & it matches perfectly no matter where I touch up.Oh, and I also agree that for those keeping it in the water, you need to use something else besides factory paint.
OptionsDream_Inn Member, Moderator Posts: 7,562 modSand and a little paint is probably fine. You may want to use the antifoul though afterwards to help keep the barnacles off.
There is a nice post on here about prepping and painting. Prep is critical for painting over aluminum.
http://www.boatered.com/forum/topic.asp?TOPIC_ID=97217
http://forums.iboats.com/forum/boat-repair-and-restoration/boat-restoration-building-and-hull-repair/461196-self-etching-primer-vs-zinc-chromate
06 Rinker 270
