Two Koehler 5e questions: breaker & choke
two questions
1- how much spring tension should be on the choke? I assume "just enough" as too tight and it will have to work hard to open when warm and too loose and it won't close and will be hard to start cold. Is that the answer, just barely enough that you just barely feel the spring holding it back when cold?
2- has anyone replaced the 42amp carling breaker? As circled below the end of the switch broke off, I did it trying to bend over the darn thing fixing something else. Looks like a replacement is very hard to find and expensive. I can still easily turn the breaker on and off and I ran it for 10 hours plus last summer with it like this, it's just most of the switch is gone. Can anyone recommend a replacement or should I just leave as is since it is not impacting performance and is still functional?
That breaker: You need to know the "Variation number" of your generator model. It will be a 1,2,3 or 4. I'll make a bet the Var 3 using the 42A breaker. partsfortechs.com has this for $29.12 (direct or on ebay). I'd replace it.
i will put the breaker on the not needed by launch but need to do sooner than later list. BD, how can I tell the version? Is it marked on the genny somewhere? Or give partsfortehs my serial number? Thx
