Is anyone using the Blue Seas System e series battery switch?
Mercury2005
Member Posts: 141 ✭✭
I pickup up a Blue Sea System e-series manual battery switch and was wondering if anyone else has installed one?
My original battery switch has positive wires attached to both battery wires and those wires route to the switch panel for other operations. I would like to wire the new switch so that everything is off when the switch is in the off position, EXCEPT for the bilge pump.
Any insight on this from anyone?
I added a second battery to my 232 and put BSS 9001e switch plus BSS Automatic Charging Relay (SI-ACR) that charges both batteries whether using one or both batteries. Overkill on a 232 but dread a low battery while on the water. Doing this will isolate a battery that is low on voltage and lock it out from draining the other battery.
I also have a portable battery charge pack. Having portable battery charge pack on a boat, you need to make sure it's charged up or its worthless. Just another battery to keep charged. With battery switch and ACR I know I have a battery that is charged. I also added the LED light on dash that let's me know if I have a battery issue while running engine.
