Mounting TV to Arch
Liberty44140
Member Posts: 4,340 ✭✭✭✭✭
I am planning on mounting a TV to the radar arch on my 342. Location will be on the stbd side above the helm backrest so it can be tilted to any angle in the cockpit and the dock behind. Has anyone done this? There already is AC power under the cabinet for the fridge and freezer so it should be easy to run AC to it. I plan to go hidden wires so I will need to drill a hole in the arch for wires (and to mount). Anything to keep in mind when drilling holes in the arch? I dont want to create a corrosion problem down the line (although I am in freshwater). I assume there already are wires going from under the cabinet, up the arch so fishing power up to the TV will be a breeze, right? Let me know what you guys have done, thanks!
I plan to use this mount, 100% steel:
https://www.amazon.com/Mounting-Dream-Articulating-Extension-Adjustment/dp/B00ZKGVK30/ref=sr_1_2?s=audio-video-accessories&ie=UTF8&qid=1470189389&sr=1-2&refinements=p_n_feature_keywords_three_browse-bin:6787468011,p_n_feature_keywords_two_browse-bin:6150418011,p_n_feature_browse-bin:2257256011
Greg, I hear ya on the DC option and we may go that way. That said I am assuming running AC from the back of the fridge/freezer area up the arch would be just as simple. Perhaps run a 16g cord and attach 3 prong ends once the cord is ran.
Dan, thanks. I do like your set up however the Admiral has given orders that if a TV is to be mounted it will be over the trash can. I'm not arguing What do you mean by the Amplefire behind the galley? For the antenna? I assumed the antenna amplefire is behind the TV down below. Thanks.
Hardware stores have aluminium 1/4" × 1" x 3 ft flat bars. Cut, drill accordingly to create a L Bracket. Mount the TV bracket to that. In the back side put foam tape to protect arch and possible speakers from scratches. Custom and clean! I did this on my 320 and posted pics here some time ago.
Mark
I actually was able to get a piece of backer board behind the mount in the arch through an access panel in the arch. I then drilled the holes in the arch and put 5200 on the backer board and then bolted it in like having a stud in the wall. The mount I used is a full swivel mount 180 degrees. I then had the cover made with snaps in the arch to hold the TV in place while under way. It has never given me any issues. Good Luck! Should be about a 6 beer project, pretty easy.
https://www.amazon.com/Ergotron-Quick-Release-Bracket-60-589-060/dp/B000W0ETD2/ref=sr_1_1?ie=UTF8&qid=1491398725&sr=8-1&keywords=monitor+quick+connect
Yes I was able to actually get a piece of treated 2x4 behind the arch. Ours stays in place year round with the cover it really does help.
Side note, if you have good wifi at your marina or if you can tether from your phone and have a smart TV you can hook up a slingbox system. You can have all your cable programming from home to your boat with just a wifi signal. We love it, and my wife never misses any of her favorite TV shows from home.
https://www.amazon.com/gp/aw/d/B07KBW29P8?psc=1&ref=ppx_pop_mob_b_asin_title
