Length of VHF Antenna Cable?
WillhoundWillhound Member Posts: 4,239 ✭✭✭✭✭
Need to replace the VHF antenna on a 2000 FV270. Antenna is mounted on the starboard side of the radar arch, so cable will be routed down the arch, along the hull to a flush mounted radio in the dash.
Does anyone know if a standard 15' long lead is long enough for where it needs to be fed? I'm thinking it should.....
