PCM shows that engine in gear
davidbrooksdavidbrooks Member Posts: 1,408 ✭✭✭✭
So I was troubleshooting an issue with the engine and was going through the readings on the PCM and noticed that one of my engines shows up as "In Gear".  The engine is a 2003 Merc 350 MPI. I haven't tried checking if the props are spinning yet but it starts fine.  Goes into gear forward and reverse but doesn't seem to change the PCM readout.  I would think that if it was in gear it wouldn't start.  Anyone run across this before?
