Passport thermostat display wrong room temp
Stodge
Member Posts: 2,738 ✭✭✭✭
We splashed on Friday and it's been decently warm (70s) but last night it dipped into the high 40s. I went to turn on the heat down below and the room temp display says 85. Then the A/C kicks on. At this point it was about 65 in the cabin. Not had this happen before. Tried turning off the power to the unit and trying again. Same thing. I was thinking of doing a reset on the thermostat. Any other thoughts?
On a high note I have a Passport II board and display for sale.
As for the adjustment, http://www.dometic.com/QBank/EPiServer/Dometic/US/Manuals/Marine-manuals/Air-Conditioning/Controls/AH-Passport-2-CW-Operation-Manual-2165_15165.pdf Page 9, setting U-5. It worked the same on my Passport.
@08177as....I posted the instruction manual a year or so ago on the forum it may be in the archives. If you can't find it maybe someone can scan it for you. It is very helpful and shows how to program almost every code.
P.S. I just went to the search box at the top of this page and entered "passport manual" and I found the discussion pertaining to HVACs there are some good posts there and I did post scans of pages of my manual and it works for many of the Rinker installed HVACs - have a look - good luck!
P.P.S. If you enter "passport manual" a page will open. Click on the thread "HVAC not pumping water 2007 280EC"
Open that thread. I have posted several times with scanned pages of trouble shooting ideas, code programming suggestions and electrical wiring diagrams for the passport HVAC system. There are also lots of good comments from forum members - good luck MT
