Wet floor
Ransnan
Member Posts: 81 ✭✭
We have a 2003, 342. Woke up this morning to a totally saturated floor mostly in front of the bathroom door, I believe it's NOT coming from the fresh water supply, my thoughts is that is is raw water for the toilet, there's no odor , so I know it's not sewage leaking, thoughts on the problem and solutions ???? The storage compartment in the aft is just slightly damp!
2. Check for leaks at the AC raw water pump
3. Check your toilet and AC strainers for leaks
4. Is there water in your mid-berth bilge? I had leaks in the hoses from the shower sump outlet and the outlet tube from the bilge pump.
Any of the above will get that area wet. Been there!
The float/pump in the shower sumps can go bad and overflow.
