A/C raw water valve open or shut when underway?
I've always been in the "shut" camp, because the P/O told me to do that.
however others alluded to they don't shut the ac valve ever and it works just fine.
Tested it out today... checked the mid bilge where the AC water pump was before leaving.. left valve open.. result = 5 gallons of water in the mid bilge (salt) after a short trip.
Is this normal? I've been on other boats with AC where they don't do anything at all, which is why I figured I'd test this out.. appears I have a leak when pressure builds up? Any thoughts are appreciated.
During normal use, I never close my water intake valves. For a lift-kept boat, closing the valve before lifting can make it easier to prime the pump when you go back in the water.
When I got back to the dock at the end of the day it had 5 gallons of water in it, no AC was used during this time.
I did vacuum it back out and ran the AC again to see if it was leaking and didn't see any.
Looking at the trap a little closer it has tons of microfractures in it.. time to replace..
FYI: I read in one of my insurance policys that stated to close all sea cocks when boat is not in use. I wonder how this effected any claims?
Took the trap off...with the valve shut.. waited for all the raw water to drip out of the hose... wait a second...why is that drip still dripping...okay maybe it needs a little more time. Hmmmmmmmmmm still dripping!
Raised the hose up to get some of the water out, and then put it back down.. drip stops. but within 30 seconds the hose is full of water and it starts dripping again!! Which I can only deduce to being a leaking valve. Wtf. Does the boat need to come out for something like this?! please tell me it can be fixed in the water!!
For the mean time I'm going to see if I can go find one of the screen housing things.
Edit: Cleaned my strainer and everything, still leaking.. sigh.
Going to try and figure out a way to put another valve inline or go get a strainer, already hit one marine store and they don't keep them in stock.
put a new valve inline on the other end of the hose, that is taken care of. No more leaks from that line. NOW we have a new problem, took the boat for a 10 min cruise under 10mph and there's PINK water down there.. indicating it's from the fresh water tank that is not dewinterized yet. WTF.
Well that solves where 5 gallons came from yesterday... notice how the water is leaking from the VERY TOP part.. not sure how to go about fixing this but for now the fresh water system will be turned off..
Looks like there are now three things to get done:
1. Replace mid bilge pump hose (it has leaks) where the heck do you even access this from??
2. replace strainer for AC
3. Fix the above picture.
gasket is SG-R-E and the strainer it's 50 mesh SE-R-50CSS
