2004 FV270 Mid Bilge pump hose routing... anyone replace this?
Noticed my forward bilge pump line is leaking when it runs. Anyone have any clue on how to access the line at the thru hull? I was dealing with a couple other problems today and didn't take a super close look at it.. hoping there's some panel that easily comes off!
Best Answer
Cableguy Greg Member Posts: 5,066 ✭✭✭✭✭
Check the locker, if you want to call it that, under the sink in the head. If it isn't there, it should be behind the A/C unit.
I do still have a pretty big problem, the A/C thru hull valve leaks a pretty large amount of water every second or two.. I put a valve at the other end of the hose to solve the problem for now.. not sure how safe that is.. will post pictures this weekend. Would REALLY like to avoid the $400 charge to have it short hauled and put back on blocks until the boat yard can get to it (they are absolutely hosed with work right now)..
Searched the Web and could not find it.
One problem with this is the bottom of the raw water thru hull on this boat isn't just a hole like that.. it has a cover on it with slits in it..
like this...
not sure if it's metal or not, but obviously the video wont work
The yellow handle is the one that leaks, put the blue handle valve in and a new strainer...Don't see any leaking when ac is on or off, time will tell though. Anyone see a reason why this fix is dangerous it wrong?
