Radio/speaker issues
hello,
the 2 speakers in the cabin work, but the 4 up top do not work. It looks like everything is connected. I tried the balance. Any suggestions?
Also check that you have a good ground. I ran into this problem installing a system this weekend and I was ripping my hair out. It is also very possible that the amp needs replaced but check to see it is getting power and ground first.
It looks like Sony quit making this amplifier. There are a lot of equivalents out there. Rinker used car amplifiers in the cabins of these boats. Marine amplifiers offer a bit more corrosion resistance and shock resistance but you pay for that. To match up you want to get a 4 channel amp around 600 Watts. You can always turn the amp down if it is pushing too many watts.
Here are some marine amps that are out there. https://www.sonicelectronix.com/cat_i2621_4-channel-marine-amplifiers.html
Boat: 2004 232 Capitva CC
Boat Name: Mixed Nutz
the rest of your system sony ?
any thoughts of upgrading ?
have to decide what you really want it to do....lots of choices
might be a good time to get new ... if your not sub n a nice amp and head unit somewhere around a half stack or a bit more
